Reskin Roof..
What do you know about options about ways to go about reskinning a roof with a stock panel, sunroof delete panel, fiberglass panel, carbon fiber panel, whatever..
And how to go about installing any of these options..
if your top was dented how would YOU go about fixing it?
Bodywork is one of my weak points..
Are any of these options more or less difficult? Take more or less experience/skill?
Can a skin be pulled from a parts car?
Really depends on the cars purpose… if it were a track car and caged out I would do a fiberglass panel. If it’s a street car I would cut a roof off a good donor and weld it on. Also depends on the size of the dent as well. Generally especially if it’s not a structural area and just sheet metal area I would patch it, you will have some filler generally no matter which you do.
metal you will have to cut out, tack weld replacement in place (move the welds around, not next to each other as it can warp if you do the same spot back to back), grind welds, skim coat of body filler, sand and paint.
if doing fiberglass I would cut it out leaving a 2-3inch lip to lay under the panel and then use a 3M Non-Sag structural adhesive to bond the roof to bare metal. Once cured then I would sand, body fill, sand again and paint.
What do you mean by patch it?
I’ve actually got almost all of the dents out and have it all straightened back up as far as the sunroof hole height..
I think I’m going to try to smooth the rest of it out with body filler first and see if that will come satisfactory..
Why not fiberglass for a street car?
I saw those and that looked about like the easiest option..
968 Gene did this (replaced the metal skin with another non-sunroof skin) to eliminate the sunroof. A lot of drilling with a special drill bit, then a lot spot welding to make that swap is my understanding.
