944S2 driveline whine noise at speed.
Millermatic- I suspect my ring and pinion are headed out on my 1990 S2, but I am wondering if you could describe what you felt in your shifter (vibration? Rpms? Etc.). T might help me diagnose my problems.
Hope that helps.
For what it's worth... new ones are available from Porsche... but they sure aren't cheap.
The most obvious issue was the noise. It was uncomfortably loud in the car above about 55mph or so. Totally speed dependent - not gear or RPM dependent. I could feel a vibration at the same "frequency" of the sound if I placed my hand on the shifter. Not really intense... but notably different than at lower speeds.
Hope that helps.
Hope that helps.
1000 Euro's isn't far off what I paid (about $1200 as I recall - which included expedited shipping).
But... that was on top of getting the transaxle rebuilt. That was about $2500 for labor and all new bearings, synchros and seals. Plus shipping ($200-ish for "freight" in the US).
And... if you are going through all of that trouble... you might as well get some "super bearings" and have your TT rebuilt. And your clutch... And your pilot bearing and rear seal. And your transmission mount... And CVs...
But at least my drivetrain is... basically new now!
My go to suggestions for all noises-
1. Get someone else to drive. Start by listening from the passenger seat. Then put yourself in the trunk area and move around there to listen.
2. Get some long tubing/hose. This will take some time but basically you are going to duct tape the end of the hose at those locations where you think the noise is coming from. Transaxle. Left rear hub. Right rear hub. Etc. You are using the hose as a stethescope. You may be surprised at what you find. I had a noise that I swore was in the transaxle that actually was loudest on the right rear hub.
Onwards with the investigation
Hope that helps.
Hope that helps.
Now have new tyres all round, so that is one variable eliminated. Checked all wheel bearings at the same time... all good. The new drive shafts and CVs all still look good, so no issue there.
I have driven more to try to identify the source, and during a drive I did notice that the gear **** started to vibrate as I went above 105km/h (indicated)... but then went away again. It is a resonance type of vibration, bobbing up and down a few mm... also noticed this in other gears right around 3000-3200 rpm, so this is not related to the whining noise that this thread is about, but from research, most likely the TT bearing, clutch, or just a simple gear shift linkage rubber. My balance shaft belts were done 4yrs/8000km ago, and also new RS engine mount 3yrs ago. So another symptom to investigate :P
So in response to the symptom you were experiencing with feeling the gear shift with your whine, I don't have any related feeling similar to what you describe. But it seems a new TT bearing or something between the engine and gearbox is not happy at approx 3000rpm in any gear.
Thought I would share an update...
The vibration in the gear shift is actually 2600-2800rpm only. Not 3000-3200rpm.
Qtrfoil (07-02-2023)
There is still a vibration in the shifter only. Still just between 2600 and 2800 rpm, varying in intensity depending on what gear. No noise present with the vibration.
I am guessing it is the shift connection dampener, but yet to replace this - Winter project :P
