35w Halogen from IceShark
#31
I need some spares, so I'll take 4 of the 35W halogens. I might as well get 6 of the 1155 and 2 of the 1157 while I'm at it.
You other guys might consider ordering some spare halogens, too, seeing as how IceShark is the only source.
#32
I get to it this next week and tally up all the orders. I was going to do that this weekend but some orders are still coming in and I was sort of tied up on other things.
#34
Joe, OK, if you get 10 to cover both your Porsches then we have cracked the 50 mark if most everyone on this thread follows through.
Ribs, now how many exterior bulbs do you want? The standard pack of (5) 35watt #1156 halogens, (6) #1155, (3) #1156 and (2) #1157 ? The other non-halogen bulbs only cost $9.00 for the whole exterior of the car.
TonD, so what exactly do you want? You said (4) of the 35 watt #1156 halogens, "some" 90/100 watt H4s, and maybe an adjustable voltage regulator. Make up your mind quick.
Paul K. , now how may bulbs do you want as your e-mails had 2 different quantities: either 1 or 2 90/100 watt H4s and either 3 or 4 35 watt #1156 halogens. Let's firm that up for my final list.
I think that should do it for the reason David started this thread and I will get the order in when most of you confirm what you want. If anyone else wants bulbs and is not in better sign up now as it will be the last order for awhile.
If anyone also wants:
90/100 watt H4 @$12 each,
55/60 watt 30% boosted H4 @ $10 each,
55/60 watt Osram BiLux 50% boosted H4 @ $18 each,
55 watt H3 @ $5 each,
100 watt H3 @ $7 each,
let me know as I need to order some more of them.
In the last bulb group order the shipping and packing materials came to between $4 to $6 per box depending on the size and weight. Looks like I need to go buy some more smaller boxes.
Either confirm your order on this thread or send me an e-mail at wraydan@msn.com. Don't PM me as my box will get full and start bouncing messages.
Dan
Dan
#40
Defending the Border
Rest In Peace
Rest In Peace
Dan,
Considering the rear endingings that prematurely kill so many of our cars, confirm me for five (5) 35 W'ers.
Thanks, Kevin
Thanks, Kevin
#43
Dan, I need some H4 bulbs and lenses. Not sure what h4 to go with though. I already have the waterproof relays I am going to be rewiring everything. Let me know how much and I will send you the money. Will need to talk to you offline on how you want payment since I am stuck in Ireland until the end of June.
#44
Isn't that WAY over the stock rating for the wiring / sockets? I know Ice is pretty good at doing his homework, but I just swapped out some bulbs on mine and I believe the rear light was 5W, the underhood was 10W, and the turn signals were 5/21s. If I go pumping these all up to 35W, that's a significant increase in the electrical load - am I just going to end up eating fuses? Heck, the stock lights are better than no lights!
What about LEDs?
What about LEDs?
#45
Dan [/B]
Dan [/B]
