Shoutout to Bruce and Arnnworx tools / beginner timing belt change
Hey all, just wanted to post a quick shoutout to Bruce at Arnnworx and thank him for his excellent service and support. As a beginner mechanic doing my first timing belt, balance belt, water pump, balance shaft seal project I got his 944 tool kit and would very highly recommend it to anyone, especially beginners like me. I can’t imagine trying to do the job without the pin wrench and the thin 24mm wrench and the flywheel lock and tension gauge worked perfectly and were pretty easy to understand with the videos and tips here.
I was pleasantly surprised by how responsive and supportive Bruce was when I had questions and got myself into trouble - and of course this forum was incredible as well and invaluable to completing the job. Highly recommend doing business with Arnnworx - for me it was worth every penny.
cheers!
cheers!
The following 4 users liked this post by rludlamjr:
944Fest (aka Dan P) (04-09-2022),
DSMblue (04-10-2022),
mazdaverx7 (04-11-2022),
voodu3 (04-10-2022)
You should try his rear wheel bearing removal tool ... it made changing the rear bearings on my 911 go like butter !
Well engineered and highly recommended !
I also have his timing belt tool , but i've removed and installed so many by now that i go by the twist method.
Cheers
Phil
Cheers
Phil
