I'm looking for 944 N/A power upgrades
Campeck Rulez
Originally posted by Bhj0887
Maybe if you did the 3.0 swap ($$$$$), or bore the 2.5 a little, 12.5 compression pistons, agressive cam, headwork always helps. A 951 trans can help your times maybe.
interesting.
boring out the cylinders?
I was told that would be dangerous.
and with higher compression pistons?
12.5 WOW!!!
how much of a horsepower increase would the compression be?
Well...the S and I think S2 are 10.9:1 stock. 12.5 would make pump gas your sworn enemy! Just by bumping the CR alone, I think it's roughly estimated as ~7hp per full compression point.
Originally posted by URIN 2ND
Well, it's no secret how to get power from a N/A motor.
But if it's intended for a specific racing class in a certain sanctioning body, it's pointless to even research what power is possible until you know what you're allowed to do to the motor.
If you're just trying to get as much as possible, you could max out somewhere near what a stock 951 would make (close to 200 at the wheels) if money was no object.
More typically, the basic I/E SCCA runners are getting low-130's to the wheels on basically stock motors. They are allowed a filter, an exhaust, cat delete, and maybe a header system...but that's about it.
High compression, a ported big valve head and a nice cam would certainly be in order if you want respectable power fro that motor.
However...and I'm sure many here will agree...you don't *need* gobs of HP to make the 944 competetive on the track.
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
For one thing you need to know what your competition is. For me to be a consistent winner in SCCA ITS I would need about 190 hp to the wheels. Aint' gonna happen. Spec classes are spec classes and don't factor in. PCA racing? Well, considering he's in Europe, I think we can assume it's not PCA racing. How much power he'll need will depend upon the rest of the class.
Time and time again I hear of N/A 944's hanging with or beating vehicles with considerably more power. This car is all about balance. It can get out of it's own way, has a decent TQ curve, has good roadholding, and excellent handling characteristics.
I think to be competitive on a road course, your money may be better spent on a solid suspension, and there's a number of choices to be made there!
At any rate...expect anywhere from 125 wheel HP (completely stock early 944) all the way up to the 190's wheel HP (completely built with mucho dinero invested, we're talking taking out a 2nd mortgage here). The basic bolt ons should get you between 130 and 140 at the wheels, thereabouts.
Campeck Rulez
hmmmmm.
what gas would you pump then?
and if i were to get the S head I would need a set of S pistons as well?
Campeck Rulez
and wouldnt if you changed compression you need to modify the dme?
and if you got a racing cam with that much compression would the valves get knocked up?
knocked up...heh
knocked up...heh
Campeck Rulez
wow.
I just hit my 1000 mark.
THANKS TO EVERYONE HERE FOR YOUR HELP AND ANSWERING THESE QUESTIONS AND THE FREE MEMBERSHIP!!
I really do appreciate it!
Wow Geo...you're a real a$$hole! And don't let the smiley fool you. I truly mean it!
Boy, if your driving ability were half of your ego, look out Schumacher!
I'm pretty wide off the mark? Maybe that's because my mark is based on real-world results, and you're generalizing numbers. M758 and his 944 Spec Racing website is where that number came from, and there are multiple dynos of Spec cars with those exact mods making low-130's.
Another user dynoed his stock '84 a couple weeks ago and posted his 125 WHP.
The higher numbers were based on Anderson's work and conversations I've had with Milledge. If you want to argue their results or opinions, be my guest. You know how to contact them.
So...you're either telling me that their dynos were incorrect...or you were just caught flapping your gums without doing a little legwork yourself.
Most of your comments were equally worthless and/or incorrect. I don't know why you chose to pick apart my post...it's all pretty general and widely known info. I was only trying to help.
Commonly available intakes, headers, and exhausts won't do much of anything for these engines. And you're pretty wide of the mark on output to the wheels (about 10 hp less).
131.7 WHP...
![](https://members.rennlist.com/m758/Joe94-131hp.jpg)
132 WHP...
![](https://members.rennlist.com/m758/Paul132hp.JPG)
133 WHP...
![](https://members.rennlist.com/m758/TimDyno.JPG)
...should I post more, or is your foot wedged deep enough down your throat yet? Just let me know, there's plenty more where those came from.
132 WHP...
133 WHP...
Anders,
Have you friend write to Jon Milledge. Jon has done extensive brake dyno testing with these engines. He knows which heads flow better than others and I'm pretty sure he know quite well what valve cuts will work best as well as a host of other things, although the valve cuts I'm sure is proprietary information.
He can advise on which cams would work best as well as cam timing. He has done extensive dyno testing with headers and exhausts. He knows exactly how to make power with these engines.
He has a "ITS Organizer" for an SCCA racing class that discusses all aspects of building a car for this class. It 's $100 and may not be worth it for the class your friend is building a car for, but it might be - espcially for the discussion of ideal factory engine components.
knocked up...heh
knocked up...heh
My memory was incorrect on the dyno stuff. I admit it.
well.
I mean wouldnt the valves go down deeper and the piston come up more?
and hit?
well.
and hit?
What I think you are thinking about it volumetric efficiency which is how well the cylinder is actually filled. Cams do affect this.
Interference between the valves and the piston are another matter.
