Fuel tank Sender???
Fuel tank Sender???
Ok im on a quest to find a alternative instead the dreaded 400$ sender. I have for one at fuel safe but still looking. I screwed up and did not measure the depth from the tank flange to the floor of the tank. I have since dropped the tank off for cleaning and asked the gal at the Rad. shop to do a quick measure and she hit 11 inch to the bottom sound rt?? I know theres someone out there that has a tank out. Im running out to the shop to hopefully find whats left of my sender and measure it. Any input is good.
Edit I found the cyl. which hits 8 & 3/8s call the whole thing 8.5 that 215 mm you could get away with 220 I would think.
If you have a late car, FCP Euro has it for 225, genuine Porsche, and lifetime replacement warranty. Hard to beat that!
https://www.fcpeuro.com/products/por...or-94464103701
(Am I allowed to post links to companies? I never know...)
I have a 84 with steel tank. So thats the kicker. I have gathered quite a bit of info but I need to compile it into a easy to read format and not a book. Hang in the with me.
Funny, I bought a new one from FCP Euro last year, for an 84 with a steel tank, and the total came to $125 including shipping.
And, it even has a LIFETIME WARRANTY!!!
You know I dont remember exactly where I saw it but back in the memory banks I seem to see that # somewhere. Like I said I have done some leg work for alternatives. That being said I did not find one that had the fuel light lead but as I mentioned to Farah earlier today if I can get away with something reasonably accurate with out the light and have money for a short shift kit then thats my logic. I did find a couple of options and a few ideas. I just need to write it up. Mean while Im putting a BBQ pit together it was easier to get the trans axle out.
FCP Euro has the gasket in stock but does not list a sender for 84 944 unless I pushed a wrong button. I stand to be corrected https://www.fcpeuro.com/products/por...por-477919051b
Heres the on 9440nline sells for $367. https://944online.com/air-fuel-syste...ding-unit.html
Heres the 928srs sender thats $159. https://928srus.com/products/928-641...pr_seq=uniform
They dont look the same.......
Edit: I just did a bunch of searching and almost everywhere I looked these senders were about $400
Talk with VDO America..They'll hook you up with a vendor..Seems that I bought one a few years back for about 150ish..Have you tried rock auto and Parts geek? I even bought one similar for another car project and got it for about 70.00. HTH some.
Tiger this is the whole idea of my search. I planned on calling VDO and see what they say I also have tech ? I have been side tracked with other things but simply put theres a few options out there that will work but length will be a factor and the low fuel light would probably be non functional. I spoke with farah7 who has a older one that he is going to send me so lets see what happens there. I can afford to by one of those new factory units but it would me feeling angry. Less expensive alternate solution would allow me to spend money somewhere else like a short shift.. Ill try to write up what I find out.
Outstanding buddy much appreciated. I had another member PM me about a short shifter he had that is not using so we will strike a deal. This is great forum. For those following I spoke with Patrick and also mentioned I have a 68 Mustang Coupe that I have in the shop with full Pro Touring Suspension underneath thats in the works. Whether you are a Mustang lover or not the Vintage Mustang Forum is a cool place and a host of good people there also. Hop over and see a few things.
Fuel sender received. I have not opened it up yet but hopefully I can straighten the tube some and or get mine in order and see if I can rescue it. Ill see if I can document some of it.
