Alternator woodruff key?
I recently replaced my dead alternator with a new one, I did not notice until after I put it on (while I was taking a woodruff key off my cam) that it didn't have a woodruff key on it. The fan and pully have a slot on them and I'm pretty sure the alternator has a slot on it aswell. My question is where can I find this woodruff key?
thanks for your help
Austin
Austin
@MAGK944 is correct, you can buy a new one but, in my limited experience, none of the alternators on my transaxle Porsches have the Woodruff key on the alternator. I freaked out about it when I rebuilt the alternator for my 928 S4 and got talked off the ledge about it. My experience is with the 4V/cyl cars, however, so take this all with a grain of salt.
Good luck
Good luck
Good luck
Good luck
You torque that thing down pretty good with an impact wrench and I don't think you'll have anything to worry about. It IS a little freaky, though, when you see that there's nothing there.
I'm pretty sure I ended up buying some keys that would fit the alternator, so I can send you one if you want, but I didn't end up using it.
Cheers
Cheers
