As the homeys say..."yo I lowered my bizride today 4sure"...with pics!
Nerd Herder
My BSME Finally proves it's worth.. LOL
After studying metallurgy there is truth to stronger (or hardened) being more brittle. As metal reaches it's annealing point, and held at temp for hardening, the metal tends to snap instead of stretch due the the malleability changes in the metal's structure.
We used R52 (rockwell) custom spec SS hardened bolts in a lot of applications, and the bolts tended to snap when stressed rather than giving (or stretching) and staying together. This was in a low torque situation (under 150 Ft Lbs)
This is especially true when the bolt is subject to heat/freeze cycles. as the bolt weakens it tends to snap in place leaving the threads in the mount point- as opposed to , let's say CV or head bolts that stretch. Both need periodic replacement- but the less hardend bolts are usually more removable in a single piece.
I don't think 130 is much differant then 105. The car was stable when it broke, but that may be because I have the car so stiff. Either way this won't happen again once I get the proper adapters.
The Hoffinator
damn kevin! i didnt know it would be that bad. my parts shippment didnt come in today. email me at woodstk699@aol.com if you need help replacing it on saturday (if you still plan on doing it saturday.. that is.. ive gotta do the work thing on sunday )
Unaffiliated
WOW!! Those rims look like they are in the back seat! OUCH!
I'm no metalurgist, but I know it's the tree that bends with the wind that survives the storm!
