Rear Hatch Latching Seal
Thefu
944-512-365-01 and 944-512-366-01 are listed in the PET as the pn's for L and R hatch latch seals. However, when I plug those numbers into Sunset Porsche it states that these are not compatible with my '89. In fact it only shows compatibility with the 924 (https://www.sunsetporscheparts.com/o...ck-94451236501) . Pelican's page shows it fitting 944s up to MY1988 (https://www.pelicanparts.com/cgi-bin...istory=catalog). Can anyone shed some light on this? Will this fit the '89? Is the pn for the '89 different? NLA?
TY!
I ordered and installed these very seals into my 89. Appears to match the PNs you listed.
https://944online.com/body-gasket-for-hatch-pop-up.html
SeaCay (10-24-2021)
SeaCay (10-24-2021)
I'm not seeing an 02 version listed at Sunset or Delaware. And as far as looking up parts at any of these dealer sites their catalogs have many mistakes and P/Ns I know are correct their catalog says "This part does not fit your 1990 944 S2 (or 1989 944 Turbo).
SeaCay (10-25-2021)
Showing in stock but idk how accurate that is, best to call them first and check.
944-512-365-02
944-512-366-02
SeaCay (10-25-2021)
Yep, you are correct. I just looked up the 01 part and it did not supersede to the 02 part, which seems odd if they are functionally the same. The 968 hatch is slightly different than the 944/951 as the sealing rubber is mounted to the body instead of attached to the hatch, so it could be that these two parts are not necessarily interchangeable? Would be good to know since the 02 is less expensive.
Thefu
The following 2 users liked this post by SeaCay:
944Fest (aka Dan P) (11-05-2021),
DSMblue (11-05-2021)
SeaCay (11-06-2021)
