OT: Twin Turbo - 30lbs of boost - 1900 HP - 7sec!
#32
that is just a twin reg setup.......the one feeding into the other is still considered a sequential setup. wasnt that the way the supras were? and dont the tt 911s use sequential but on seperate banks?
#33
I can still go around a corner quicker....
#34
#36
TRB0 GUY
That setup is from a 3kGT VR4 isn't it Apexx?
From what I was taught that isn't a sequential because the turbo's are feeding the intake. I was taught (though maybe incorrectly) that a sequential setup only meant that the exhaust gases went into one turbo whose compressor drove the second turbo. Then the resultant charge was driven into the intake (Kinda like the one shown last page).
If "sequential" only means they run to the same intake, please show me a car that has separate intakes (except the Ferrari's). Would that not mean that 99% of the turbo systems out there would be considered "sequential"??
#37
i think a lot of the high powered single turbo setups that some are talking about (like 4 digit hp'd single turbo converted supra tts) are not setup for drag racing at all. they are more dyno queen setups.
the car isn't my cup of tea either but its still a very impressive!
"wow.......is it a 5.0 based or 460? that is nuts." cant tell but look at those F'n hotsides!
#38
Originally posted by red9four4
i think all the big hp guys use superchargers... top fuel dragsters for example
Turbo's are much better for engine efficiency. All that exhaust energy would be wasted otherwise... I'm not discounting what you said... but 1900 is big hp if you ask me.
#40
Originally posted by cpt_koolbeenz
Not very efficient... Why rob power to make power?
#42
Trust me I am by no means saying that I know turbo charging forwards and back but after reading Corky Bells book and working for Bob Norwood for four years and going to Speed Week at the salt flats for three of those years. I have seen and worked on a lot of different turbo systems. There are a lot of diesel trucks running compound turbo systems at the Bonneville Salt Flats time trials. You want to talk about a maze of pluming some of these trucks that have large displacements are running triple turbo compound systems to get the high air volume and boost in the 80 to 100psi range. Oh as late as it is I may have screwed up a point or two just point it out.
#43
But wait, you guys forgot about variable pitch turbines. These are especially slick, as they give maximum boost at all rpms. I have heard them on a couple of diesel work trucks.
