Bearing Replacement Question
#46
Might need a puller for the front hub races. If you try to hammer them out use a ponted punch or brass drift or you will scar the hub counter bores that the races press into.
The rear bearings on the steel arms are a slip fit. Not the press fit as with the front hubs.
Any gray looking bearing grease has moly in it.
