Pics of IceSharks' battery cable kit.
The other topic was getting a little long so I'd thought I'd put this pics in their own topic for anyone interested who may not want to read through the other.
This is a close-up of the Pos cable to show how well built it is. Notice the careful heat-shrinking and inline fuse:
Close-up of cable end (cat hair not included).
This is the battery ground:
The positive cable:
The supplemental engine ground:
The supplemental positive for the relay/fuse box:
And all the extras (dialectric grease is missing from the photo but come in kit):
The positive cable:
Done With Sidepatch
Oooo..I need those plastic ties that hold the wires to the firewall. Glad I took the plunge.
Picking up the money order today Dan and will be in the mailed this afternoon.
I gotta say, Dan's wiring setups are really incredible. My only gripe is the wireharness is made of a fiberglass material...which lead to some very itchy forearms! Though i ended up selling the lightkit, ill probably end up buying it again with the battey cables if i ever get this 944 im looking at. This time however, i will be installing the kit with long sleeves on .
Haha, I really hate fiberglass too, but few other materials match it's effectiveness and cost, so...
Lookin real good Iceshark! Looks just like what I would expect from what you have said.
Big thumbs up on the quality.
Does anybody have pics like that of the headlight wiring kit?
I am curious about the plugs and relays and such.
Originally posted by Perry 951
Kevin -
That bolt is used in the event the 150amp fuse blows.
Kevin -
I can't answer that as I haven't installed them yet. Maybee Dan (Iceshark) will answer.
Daniel
Kevin -
Kevin -
Do you change that entire 6" section to change the fuse? Or is the fuse inside that black case? Where do you get a spare?
But my original question is, in normal operation, how do you make sure that bolt does not touch anything? The positive cable is already very close to the windshield frame and hood.
Originally posted by 89magic98
OK, that would allow you to bypass the fuse if it blows, in case of emergency.
Does that make sense?
Daniel
Strekfu....!!!
Vac that carpet, man!!!
I'm about to hack up a hairball just looking at it
Jim 1987 944S (IceShark rules!!! and I've got to vaccum my house too... same problem!!!)
Originally posted by Jim 944S
Strekfu....!!!
Strekfu....!!!
But thanks for noticing......
