Pics of IceSharks' battery cable kit.
Those are good pics of the battery cables. Perry951 has some other good ones of the headlight kit on his web site for the rebuild ..... I think the ones on Rennlist have crashed and burned.
To make things clear, the nylon plastic slit tube goes over the supplemental fuse and bronze bolt and is secured with a couple cable ties. So no shorts, though it really isn't close to any ground other than the hood.
The steel bolt I include is a last ditch solution if you blow the 150 amp fuse out in the middle of Alaska or Montana. As I say in the instructions, you better know what caused that fuse to blow before you hardwire with the bolt.
TechnoDuck, Yeah that fiberglass sleeve is an itching bitch. I hate working with it. You can only imagine what it is like going through 1000 feet of it. It takes a week of showers to get it off and stop itching.
