Coolant Leaks from top of engine ..
Guys,,, you can connect the far left and far right hoses together so the coolant by passes the throttle body so the throttle body is not heated! The only one necessary is the middle going to the AOS. Cap the stubs or leave open.
OOPS sorry didn't see V2rocket post
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
