Don't have ramps or stands...
Old 04-04-2004, 02:04 PM
bloodraven
bloodraven's Avatar
Default Don't have ramps or stands...
so to bleed the clutch (the old fashioned way) can I just jack the car up and leave it there? Would it hurt anything?
Old 04-04-2004, 02:25 PM
bloodraven
bloodraven's Avatar
any help?
Old 04-04-2004, 02:36 PM
Matt O.
Lifetime Member
Matt O.'s Avatar
I'd go buy some stands. I would not trust some hydrolic jack with my life if you were working under it.
-Matt
Old 04-04-2004, 02:37 PM
bloodraven
bloodraven's Avatar
to bleed the clutch, don't I just need the rear end off the ground? Can I use just two jack stands?
Old 04-04-2004, 03:03 PM
89magic98
In the Sink
89magic98's Avatar
Front end.
Two jack stands would be sufficient. Probably would not hurt to have a piece of wood, or maybe a brick, (if you didn't want to buy one) for a wheel chock.
Old 04-04-2004, 03:29 PM
IceShark
IceShark's Avatar
If you are going to bleed the clutch the old fashion way, which I assume means a helper working the clutch, good luck! You will need it.
You do want the rear end higher than the front. I'm actually not sure you can lift only the rear end a reasonable height with the front on the ground and have enough clearance to crawl under the car to get at the slave bleed nipple.
In any event, good 4 point base jack stands are failry cheap at the local AutoZone or PepBoys and someone always has a sale on them so I would go that route. You could also stick some big logs or railroad timbers under the car if you want to be really cheap. Put whatever in the support locations and drop the hydrolic jack on the supports. Our cars are so low that if you don't have fixed supports and the hydrolic jack fails you are a dead man or a vegetable if your brain doesn't squish out too much through your crushed skull.
And don't use concrete building blocks as a support. Those can crack and drop the whole car down on you.
Old 04-04-2004, 04:09 PM
Legoland951
Legoland951's Avatar
Get the big jackstands at harbor freight tools for $12 a pair (if I remember right). My uncle knew someone who died from a collapsed jack dropping a car on top of him.
Old 04-04-2004, 04:18 PM
zehnd
zehnd's Avatar
Yep, picked up a man who's car rolled off of ramps. Didn't crush him but put enough pressure on his chest to keep him from breathing, eventually died there.
Be safe.
Old 04-04-2004, 11:08 PM
Boricua944
Boricua944's Avatar
i trust my hydro jack with my life everytime i'm workin under the car probly why i'm so nerves sometimes lol
Old 04-04-2004, 11:55 PM
bearone
bearone's Avatar
rhino ramps are less than $25 at checker.
Old 04-05-2004, 12:05 AM
DerSchlechtSpecht
DerSchlechtSpecht's Avatar
You're going to need to make yourself a power bleeder if you dont allready have one. Using the helper method is great for brakes but awful for the clutch. Don't even try the hand held vacuum pumps.
-Christian
Old 04-05-2004, 04:17 AM
BruceWard
BruceWard's Avatar
Its not worth the risk to try it without qaulity jack stands. Buy some and stick other stuff under there in case they fail.
And I second ot third the power bleeder reccomendation. Its the best $45 you can spend on tools. Much easier than the two person method.
Old 04-05-2004, 09:22 AM
nineeagles
nineeagles's Avatar
I don't trust a jack to hold up the car while working under it....use something.....I bled my new clutch slave the old fashioned way with a helper and it worked fine...no problems...
Old 04-05-2004, 04:03 PM
iloveporsches
iloveporsches's Avatar
FWIW, I've had two jacks crap out on me in the past. They went bad when I was jacking the car up. Certainly wouldn't trust one to hold up the car, even if I wasn't going under. But, I'm paranoid about that stuff, even with 4 jack stands and two ramps just to lift the front of the vehicle
Old 04-05-2004, 04:27 PM
Eric
Eric's Avatar
I second the rhinos--made changing the oil a piece of cake. Harbor Freight also has good cheap, stands, so does Sears(mine came with jumpers, 3 ton floor jack and crawler all for 100.00). You do not want to half-*** supporting your car while you are underneath torquing on things.
Quick Reply: Don't have ramps or stands...
