polyurethane bushings
my car seems to drive great on the street (27/19mm sways, 275# front springs and 140# helper rear springs with konis) but seemed almost sloppy on the autocross course. do you guys think polyurethane bushings would help remove some of that sloppy feeling? incidentally, i was on street tires with stock alignment settings.
where do you purchase them from? expensive?
I can't answer the question about improvement on the autocross. But I replaced my bushings last year with stock bushings and considered polyurethane bushings at the time. I was looking at the Weltmeister brand. These are available through several catalogs. I decided to opt for the cushy rubber bushings because I read that the harder plastic bushings transmit a lot of vibration and could start rattles and buzzes.
They sqeak like nobody's business unless you grease the heck out of it. I have them on my 83 with 31 mm hollow weltmeister torsion bars and though it handles great, they are noisy. Try Delrin bushings. I heard they don't squeak as much.
The polygraphites are supposed to be much quieter.....
Do you remember how much you paid for them Dlefko? I know I have several bushings that are pretty shot. Would like to change them if it's not too much trouble....once I get the belts/A/C going, suspension and brakes are my next area of upgrade (especially after seeing RT930turbo's 951 outhandling mine....grrrrrr ...but part of that was also the cheap tires the PO put on....).
Originally posted by Dlefko
i have a set of weltmeister polygraphite bushings never used if you are interested.
