Need some help here / What have you repaired or replaced on your car???
#31
ball joints
shocks-all
sway bar bushings front
springs
camber plates
tie rod ends
Brake calipers (951 parts)
pads
rotors
pad sensors
muffler
steering wheel
shifter boot
cassette box
door handle seals
sun roof seal
hatch seal
window seals
washer tees
hatch latch r&r leaked
temp sensors
oil pressure sender
TPS
AFM r&r
idle valve
vacuum lines
fuel lines
fuel-non return valve thing
water pump
rollers
front oil seals
belts
lifters
cap and rotor
spark plug wires
plugs
ref sensor
oil cooler seals
OPRV r&r
ground wires
H4 head lights
stereo and speakers
tires
I guess that's it for one year![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
P.S.
Hope no ones wives read this thread!
shocks-all
springs
camber plates
tie rod ends
pads
rotors
pad sensors
muffler
steering wheel
shifter boot
cassette box
door handle seals
sun roof seal
hatch seal
window seals
washer tees
temp sensors
oil pressure sender
TPS
AFM r&r
idle valve
vacuum lines
fuel lines
water pump
rollers
front oil seals
belts
lifters
cap and rotor
spark plug wires
plugs
ref sensor
oil cooler seals
OPRV r&r
ground wires
H4 head lights
stereo and speakers
tires
P.S.
#32
hmm in order?
pushed in bumper
flowmaster muffler
painted car
rear valance
swaybar bushings
fuel line on fuel rail=recall
throttle cam
wheels
968 antenna
dash cover
floormats
belts and seals
coilovers
steering wheel
rennlist sticker*
rollbars
hmm...dme relay?
pushed in bumper
flowmaster muffler
painted car
rear valance
swaybar bushings
throttle cam
wheels
968 antenna
dash cover
floormats
belts and seals
coilovers
steering wheel
rennlist sticker*
rollbars
hmm...dme relay?
#34
-Rear Shocks
-Springs
-Front Struts
-Tie Rods
-Brake Pads
-Front/Rear Wheel Bearings
-Ball Joints
-Wheels
-Catalytic Converter/Exhaust hangers/Nuts&Bolts
-Clutch and all the goodies
-Carpets (everything in the 86)
-Throttle Position Switch
-Air Flow Meter Potentiometer and Board
-Air Filter
-Oil Filter
-Heater Valve
-Thermostat
-H2O pump
-Belts
-A/C compressor
-Alternator Voltage Regulator
-Chain Tensioner/Chain
-Fan Thermoswitch
-Door handles
-Console Hinge
-Glove Box Brackets
-Dash Lights (assorted, also including ashtray light bulb)
-Speakers
-Stereo
-DME Chip
-Camshafts/Valves/Lifters/etc (I try to block this incident from memory)
-Fuel Pump (if anybody has an extra bolt to attach the strap for the big metal cover please PM me)
-Sunroof motor
-Sunroof gears
-Spark plugs
-Distributor Cap/Rotor
Well, I know I'm forgetting some stuff but this is pretty accurate.
-Springs
-Front Struts
-Tie Rods
-Brake Pads
-Ball Joints
-Wheels
-Air Filter
-Oil Filter
-Heater Valve
-Thermostat
-H2O pump
-Belts
-A/C compressor
-Fan Thermoswitch
-Door handles
-Console Hinge
-Glove Box Brackets
-Speakers
-Stereo
-DME Chip
-Sunroof motor
-Sunroof gears
-Spark plugs
#35
Here is my list.... However this for the following cars
1) 88 Turbo S - Stock 120k - Owned since 97 & 30k miles
2) 84 944 - Stock Concour - Owned Since 97 & 10k miles
3) 87 924S - Owned since 90, Wrecked in 96, 10k miles Now parts
4) 84 944 - Bought as junk car built into race car
5) 86 944 Turbo - Stock 67k - Father's car Owned since 2000 5k miles
6) 83 944 - Bought as parts car in 2003, Just turned in to driver/autocrosser
All of the following I have either replaced, or had to fix in someway on one or more of the above cars.
Ball Joints • Fuel Pump • Head Gasket • Radiator Hoses • Oil Cooler Seals • Timing Belt • Water Pump • Rotors • Torque Tube • Clutch - Valves • Sun Visor Clips • Sun Roof • Rod Bearings • Front Seals • Rear Seals • Pressure Plate • Strut Inserts • Brake Pads • Interior Trim • Wheels • AFM • Vacuum Hoses • Balance Shaft Belt • Lifters • Gauge Cluster • Seat Upholstery • Headers • Main Bearings • Oil Pressure Relief Valve • DME • Injectors • Fog Lights • Bumper Pads • Strut Mounts • Parking Brake • Control Arms • Motor Mounts • Distributor Cap • Spark Plugs • Spark Plug Wires • Chips • CV Joints • Oil • Radiator • Air Conditioning System • Thermofan Switch •
Here are things not on your listing
Shift Lever
Shift Rod
fuel filter
Power Steering Hoses
brake lines
all suspension bushings
brake calipers
Balance shaft cover re-seal
fuel rail
Tranny Syncros
hood & Hatch shocks
seat belts
Heater control cable
valve stem seals
exhaust hangers
springs
torsion bars
sway bars
Mirror glass
Front Spoiler (NA)
Wheel bearings
Steering Wheel
Brake Master cylinder
Clutch Master & Slave
Ignition switch
Head light switch
power window switches
Cooling fan blades
Fuel lines
Steering rack boot
Powersteering pump
PowerSteering pump adjuster
oil cooler lines
coolant return metal pipe on top center of engine
coolant heater pipe (one that runs over the headers)
headlight relay
Turbowater pump
Coolant expansion tank
air/oil sperator o-rings
Oil pressure sender
I think that is about it.
Shift Lever
Shift Rod
fuel filter
brake lines
brake calipers
fuel rail
Tranny Syncros
hood & Hatch shocks
seat belts
valve stem seals
exhaust hangers
springs
torsion bars
sway bars
Mirror glass
Front Spoiler (NA)
Wheel bearings
Steering Wheel
Ignition switch
Head light switch
Cooling fan blades
Fuel lines
Steering rack boot
Powersteering pump
oil cooler lines
headlight relay
Turbowater pump
Oil pressure sender
#38
Rod Bearings, Head Gasket, Oil pan gasket, Vacuum lines,<--(Everything replaced on the eng exc piston rings) Master Cylinder, Ball joints, Pads/Rotors, Tie rods, Sun roof gears, steering wheel cover, fog lights, front marker lights, ICV, TPS, Fuel Filter, Speakers, Motor mounts, All belts.
That's the stuff I couldn't repair. The repair list goes much further.
Alot more stuff I can't recall due to subconscience blockage.
