Buying Oil
Old 03-27-2004, 03:23 PM
Baron009
Baron009's Avatar
Default Buying Oil
I'm at the minimum oil mark, or thereabouts and so I think I'm going to get some oil and top it up.
Any brand recommendations?
Old 03-27-2004, 03:51 PM
ljd-924SE
ljd-924SE's Avatar
mobil-1 synthetic . . . if you don't want to spend the extra on synthetic, try the mobil synthetic blend (a mix of synthetic and conventional oil)
Old 03-27-2004, 03:58 PM
944CS
944CS's Avatar
it'll prob. leak if u use that.......i'd go with castrol syntec blend 10-40 or 20-50 depending on what the weather's like
Old 03-27-2004, 04:36 PM
Mike1982
Mike1982's Avatar
I use 10-30 Mobile 1 full syn. and haven't had any leaks (Knock on wood!!)
Old 03-27-2004, 04:38 PM
Yabo
Yabo's Avatar
wait wait. you said your at the minimum mark and are going to top it off? what did you ahve in it before? you shouldn't mix grades, especially synthetic with non synthetic.
Old 03-27-2004, 04:41 PM
Zero10
Zero10's Avatar
Umm...
It's harmless to mix conventional and synthetic, hence the creation of synthetic blends. All the stories about that are urban legends.
Now, synthetic MAY cause some extra leakage, but really that is quite rare. Usually people switch to a lighter weight oil when they switch to synthetic, and that's what actually causes the leaks.
I mix grades all the time. Especially when it's getting closer to winter, I start topping off with a lighter weight oil.
It's really quite harmless.
Since you're a fellow canadian, and we just FINALLY got near summer, I would say top it off with Mobil 1 15w50, or Amsoil 20W50,or something heavy like that. But that's just a personal preference.
Old 03-27-2004, 05:00 PM
Baron009
Baron009's Avatar
I have no idea what is in it right now, because I haven't had the car long enough to change the oil. Not sure what the PO put in.
Anyways, thanks for the advice guys. Another reason for me to consider Rennlist membership sooner rather then later.
Old 03-27-2004, 05:11 PM
Yabo
Yabo's Avatar
well, what do you think of your PO. does it seem like he woudlve spent extra for good synthetic oil? I wouldn't worry too much either way. its about a quart (on most cars) between minimum and maximum, that much shouldnt affect much. but do an oil change soon to be safe.
Old 03-27-2004, 10:29 PM
83na944
83na944's Avatar
If you're down a quart, you're probably due for a change. That way you'll know what's in it so you can use the same stuff if you need to top up later.
But my car has Castrol GTX in it. I buy it in cases and never mix brands, viscosities, or types of oil. Guess I'm a traditionalist.
Old 03-27-2004, 10:32 PM
brad-cam
brad-cam's Avatar
IMHO, the first thing you should do when you first get the car is an oil change. Who knows when it was last done and with what product.
I use Mahle filters and Mobil 1 15W-50.
Old 03-27-2004, 11:09 PM
ErichCS
ErichCS's Avatar
Ditto on the Mahle filters and mobil 1 15W-50. I would also agree the first thing you should do is change that unknown oil...
Later!
Erich
Old 03-27-2004, 11:14 PM
Bones944
Bones944's Avatar
Look on ebay for mahle oil filters, I bought a pack of 10 for $28 a year or so ago.
Baron009
Baron009's Avatar
Well I have records of when it was changed last... it's been ~3000km since the last oil change, which was in late august. I have no idea of what oil was used though.
I'll be changing the oil in April/May anyways, but I just wanted to play it safe and top up the oil in the meantime.
Old 03-27-2004, 11:20 PM
ErichCS
ErichCS's Avatar
Wow! That's a great deal! I paid $45 for 10.... I'll be watching ebay from now on.
-Erich
Old 03-27-2004, 11:34 PM
Bones944
Bones944's Avatar
Why wait? It takes $20 and 20 minutes to change the oil, and your current oil is 7 mos old. It's irrelevant that it only has been 3000km, age is a determining factor also.
Quick Reply: Buying Oil
