Clutch Plate removale
hey!
I just got the clutch out and I want to remove the freeking 8 hex bolt from the fat clutch back plate, the thing that is behind the clutch, attached to the crank.
Can anyone tell me what would be the best way to remove the 8 hex bolts? I tried a a hex socket with my wrachet and a torque tube, but it seems like if it's gonna stay and strip.
I did some research, but no one has a right up on crank removal and my freeking manual is at home and I would like to get info before going tonight to the garage...
If any one know... let me know and everyone else how to... =)
Thanks a bunch --->
Charles
Thanks a bunch --->
Charles
- flywheel bolts, okay. That is a triple square. You need to make the special trip to the store to get the right socket - don't even think about putting an allen in there, or you will be one sorry dude.
Yea those are not regular allens by any means! Wait how did you take off your CV joints and the other bolts in the clutch without the triple square socket???
Anyway, these tools can be found easily at Autozone, they sell in packs of 4 an 8mm 10mm 12mm and 13mm(?). They are like an allen wrench that is designed to fit into a regular 1/2'' socket.
HTH!
Erich
HTH!
Erich
Check this out!
http://www.mytoolstore.com/sk/sk03093.html
Thats what you're looking for...the cheaper ones don't come with the socket connection at the one end.
Good Luck!
Erich
Good Luck!
Erich
Wow... good thing I asked the pros... =)
That what I was looking for an answer...
For the Flywheel bolts I was able to do it no prob with my hex socket ---> =)
But these a bit crazy looking for mine... =P
Second question of the day:
If I want to remove the rod from the crank, there is 2 nuts that attach the 2 parts of the rod together, what type of socket do I need for that?
Thank again for all your answers... =)
Charles
Charles
cool, I was not sure if that existed at all... there soooo many different tool that exist... hehehe!!
Gotta go and work on the car later tonight... everything is going as planned...
Total bottom end reseal and relap on the block/cleaning, rod balancing, main bearing change and a I'm maybe looking to put a stoker kit this time or next winter... not too sure
thanks a again!
Charles
thanks a again!
Charles
