Problem with AutoMeter Ultra Lite Boost Gauge
I have an autometer gauge that I just went to install last night.
I hooked it up to the car, but you guys know how the boost gauge rests at 0, mine rests at -11 vacuum.
I hooked it up, thinking that if I were to turn the boost up, it would go back
to 0, but it didnt. As soon as I shut the car off, the boost gauge went back
to 11 vacuum. What do I do to reset the gauge to rest at 0??
Re: Problem with AutoMeter Ultra Lite Boost Gauge
It was previousley owned.
When I hooked it up to the car, it works, it builds boost, and reads vacuum, but it thinks that -11 vacuum is the "0" point, and gives me wrong readings.
Thanks.
Thanks.
i had a brand new ultra lite boost gauge that i got from SFR. when i got it it was resting at the very lowest vacuum number. when i plugged it in it never did anything. i sent it back to tim and he replaced it for me. new one rests at 0 just like it should.
mine worked fine, it may read like 1lb vac. at an idle max, but w/ two separate guages hooked up it read boost correctly on mine. I would try to get you money back.
