Cruise Control Computer Extraction
Old 03-15-2004 | 02:18 AM
Porsche-O-Phile's Avatar
Porsche-O-Phile
Default Cruise Control Computer Extraction
Anyone out there know how to remove the cruise control brain for an early 85? I think it's the silver box behind the stereo in the center console but space is kinda tight in there what with the carpet pieces on the sides of the center console, the wiring, stereo, etc. I can't see exactly how it's connected. . .
Old 03-15-2004 | 02:43 AM
theedge's Avatar
theedge
I thought it was the flat box in the drivers footwell up on the left (clutch side)??
Old 03-15-2004 | 04:16 AM
Porsche-O-Phile
On the earlier ones it's supposedly in the location I mentioned. I looked in the drivers footwell too, but there's nothing there except fuses, relays, my DME box and a dead rat (just kidding about that last one).
Old 03-15-2004 | 02:53 PM
capndar's Avatar
capndar
I am also looking for it.....anybody?
Old 03-15-2004 | 03:21 PM
Joe Jackson's Avatar
Joe Jackson
Early 944's ('82-'85) it is behind the radio buried in the center console. Mounted with two phillips head screws, requiring removal of a cover or two on the underside of the dash to get at it. Late 944's ('85.5 on up) it is behind the carpet on the driver's side footwell next to the hood release. Mounted with two M6 (10mm hex screws).
Old 12-14-2005 | 11:56 AM
kennycoulter's Avatar
kennycoulter
so to get at this, do you go from the drivers or passesngers side? what covers need to be removed?
Old 12-14-2005 | 12:14 PM
Mike C.'s Avatar
Mike C.
On the driver's side, remove the black contoured cover (if it's still there) located at the forward lower end of the center console. The cruise brain sits right on top of the transmission tunnel and has a large black plastic electrical connector going to it. The connector is removed by carefully pulling it away from the module (no locking mechanism other than the pin friction). You will see two phillips head screws on the aft (right) side of the cruise box that hold it in place. It will slide out towards the driver's side.
Old 12-15-2005 | 04:41 PM
kennycoulter
is it safe to drive the car with the computer off? i already put my cable box thinger back on. i need to drive my car through the snow, and would like to make sure it is safe to drive if my c.c. computer is removed/unplugged.
Old 12-15-2005 | 08:03 PM
Mike C.'s Avatar
Mike C.
Yes you can drive without the cc box installed. It makes no difference to the DME.
Quick Reply: Cruise Control Computer Extraction
