Timing Belt Change gone BAD (need parts)
After I changed my timing belt, the big bolt on the end of the crank shaft came loose a little (after about 300 miles) and it ate the balance shaft pully on the crank and also damaged the alt pully (the ac pully between the two is ok) See link for photo, I need the top and bottom pullys. reply here or email at jcnnjc@hotmail.com if you have these 2 pullys.
http://images.andale.com/f2/115/106/...384_pullys.jpg
TIA
Jim
TIA
Jim
