How to align door
svb (03-22-2020)
Looks like the rear edge of the door and window frame line up well. Does the front edge of the door itself line up well?
(Curious, curtisr… what is that tool?)
It's what a bodyman would use here. The sliding bit is, of course, to allow for different window heights - insert into window opening (with window down), place protective end on the appropriate side of the upper window frame and pull on handle towards oneself.
svb (03-22-2020)
Curtisr thank you, I will try that!
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/1500x2000/img_2542_dcb356bbe5c778898a3ac191fb65e52937be1ea1.jpeg)
Curtisr, you are a genious! With a little muscle and some pushing and pulling I got it to line up perfectly, and now the window goes up and down smoothly as well. Thank you because it was really bugging me. I'm still at a loss as to how it happened, but if anyone else ever runs into this, now you know what to do.
Anyways, glad it worked out and it does look perfect.
