power steering pulley removal?
in the haynes manual it shows the timing being changed on a car with no power steering i think. it shows them removing 4 bolts that are in the crank pulley. but on my car theres just the one big 24mm crank bolt holding the power steering pulley on there and i dont see any other bolts. how does this come off? do i need to lock the flywheel then turn that 24mm bolt until it comes loose? i didnt think that bolt ever came loose or something.
thanks
thanks
You can change the timing belt with the pulleys all attached. If you lay underneath the car, and look at the gap, you can angle the belt so it slides in starting at the bottom and working around the drivers side of the pulley. It will slip right in if you have the right angle.
Oh around the drivers side of the pulley i used a flat tip screw driver to push it back onto the timing belt pulley, no force required, just my girly fingers weren't skinny enough.
since you mentioned oil pressure, does that mean im going to gave to drain my oil before doing this? it eeds to be changed anyway. but all my buckets are full of coolant at the moment.
were the heck can you get rid of coolant. im not about to go dumping it in lake michigan.
If you are going to remove the crank bolt, get a lock. The bolt is hard to remove and very hard to torque correctly without one. Also, you want the engine to stay in TDC while working on the belts. 944online has on for $34.
http://www.944online.com/accessories.asp
Originally posted by SoCal Driver
So this is for a timing belt change! Yes you do not need to remove the crank pulleys.
Best of luck!
If you are replacing the waterpump, you will need to remove the pulley, if you are just doing the belts, you can leave the pulley. If you need to remove the pulley, you can do so with someone locking up the flywheel with a flat head screwdriver through the starter opening while the other person removes the bolt. The friction of the pulley drives the oil pump, so you do not have to drain the oil. I also have a couple of gallons of coolant in my garage. I plan on taking it to some of the local repair shops to see if they will recycle it.
*Note- the flywheel lock is preferable. Next time I do the job, I will get one, but if you don't have one and are in a hurry, you can use the screwdriver method
You do not have to drain the oil to replace the belts. If you going to re-seal the front of the engine then yes you have to pull the crank pulley(s).
Take the 24 mm bolt out before you remove the belts. Yes you can jam a large screw driver or crowbar in the bell housing against the flywheel teeth. Remove the pulley(s) after you take off the belts. I've posted a diagram of how to re-align the balance shafts. Do a forum search.
Return the timing to TDC before you remove the belts. This can shift back and forth a few teeth while you do the belt change.
Auto Recycle
Any of these auto recycle centers, most are free.
Auto Recycle
Originally posted by Riff
I think this statement should say "it depends". With the wider belt on the S2, I needed to remove the pulleys to get the belt out. Then again I really did not try to "force" the issue as I did not want to damage the belt, even though I was replacing it. I figured if it does not come out easy, wasn't going to go on easy......
Best of luck!
Best of luck!
Get theeself to www.clarks-garage.com
The advice on this thread is spot on correct, but you may benefit from the 'big picture' as shown by Clark.
