Any source for LED taillights and/or recommendations?
Having replaced the headlights and fog/driving lights with LED units, I'd like to replace the taillights as well. Are there any vendors that supply them, and if so, which are recommended?
I don't know about the vendors (which I totally support going to first) but I've been using bulbs from www.superbrightleds.com. So far so good with the bulbs I've received from them and the technical drawings on the site are quite helpful, so as to be able to find bulbs which are the correct height for the fixtures.
Cheers
Cheers
I did this for my 951 from superbright leds.
1156-CW18-T: Cool White (Reverse lights)
67-R12-G-2PK: Red - 2 Pack (Tail lights)
1156-R18-T: Red (Brake)
67-R12-G: (Rear side markers)
67-A12-G: (Front side markers)
If you do signals, you need the slow flasher relay... but you can't do the fronts and the rear signals for some reason. With such little resistance, the signals don't even hyperflash, they just don't work.
1157-AW60-SA-2PK I used these for front signals in my clear lenses. They are white when in DRL mode and switch to blinking amber with the signal light.
The electronic relay replaces a factory relay in the fusebox under the hood. You don't have to find space to add a new relay. It is the one turn signal relay.
No cruise control left in any of my cars. I don't imagine that there would be an effect because I think the pedal sensor probably goes straight to the cruise control and not through the brake lights first.
