Reconditioned injectors where to buy
I honestly never had it checked (never thought of it at the time). I asked around and there didn’t seem to be any local shops that could test them (and after a long winter I wanted to get my car on the road).
Basic Sponsor
There are no other symptoms at all and on the second start the car runs perfect.
This started last spring when I changed my AOS, removing the old injectors caused the old plastic to break and as such I replaced the broken injectors..the problem started after this.
It is a bit of a shot in the dark but as the injectors are 30 years old and one was replaced with a used injector I would like to throw in a known good set. (And hope that’s my issue)
I am still maintaining my theory. If the car runs perfect at any one time, the injectors are firing fine. The injector is an electrical item, typically they operate, fail or get gummed up and perform poorly, but typically consistent. The fact that the engine performs perfect after a second start tells me the injectors are firing fine and to look somewhere else. Just trying to help direct towards more likely scenarios. I am leaning towards a bad fuel pump check valve or weak DME fuel pump relay. Good luck and let us know what you try and what works for you!
plumbum (01-31-2020)
