Shifter question
Okay in some 944's, shifting feels a lot stiffer. The gear shift has a much tighter feel to it. Is there somehting that comes loose that causes the shifter to loosen up? and can it be fixed?
Cheers,
Wagz
Cheers,
Wagz
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
The shift lever can become worn where linkage arm (correct term?) connects to it. If it becomes worn, it will cause the shift to feel loose. I replaced my shift lever for this reason.
![](http://forums.rennlist.com/upload/knob12.jpg)
