Fs freshly machined 2.5 crankshaft and brand new main bearing set
2.5 crankshaft, freshly polished by local shop. All rod and main journals are within spec, I can give you the actual measurements if interested. Crank runout was checked too and also good in spec.
I had my shop clean out the sludge traps (oil passages inside the crank, that feed to rod bearings) and they installed new plugs.
This crank is ready to run.
Also including a set of standard Glyco main bearings. These are the best bearing shells hand picked from 2 complete sets.
Asking $450 for the crank+bearings, picked up near Nashville, or shipping for added cost. I'm breaking even at that cost.
