Installing late fuel tank in early car ... tips
The following 2 users liked this post by V2Rocket:
H.F.B. (04-29-2020),
Tiger03447 (05-08-2021)
H.F.B.
I just received my late fuel tank and hardware Yesterday , including the late crossmember ... where did you cut off the old crossmember and how did you
fit the new one in ?
Didn’t realize the tank was so big , my car didn’t have a OEM fuel tank , it was all removed in favor of a fuel cell which is expired by a few years already !
Cheers
Phil
Cheers
Phil
That was the easy part.
I opened the old crossmember to look how the bolts for the transmission mount were attached.
Here is a photo.
Then I cut a slot in the side carrier to see what’s inside and found out, there are two layers of sheet metal and the upper layer has indeed two holes for bolts. So I simply drilled through the first layer. Now you have the correct position where you have to fit your thread insert for the new crossmember and the tank straps. I fitted a similar thread insert as you can see in the photo above, then I welded up the slot again.
What i want to know is , do you have to cut off the early crossmember completely to fit the tank or does it fit into place ?
I have no problems cutting, fabricating and welding parts ... like they say, measure twice , cut once !
Cheers
Phil
Cheers
Phil
Yes, you have to remove the crossmember AND the old fuel pump bracket completely.
Jay Wellwood (04-30-2020)
WOW! All this is good to know! thanks guys for posting all the pics and write-up! Maybe in the future...but not right now..What are the differences between the 951 transmission and the 016 trans found in the early cars? any length changes? I know that the mounts are different, but can be adapted over using the early mounts on the later trans..I guess that you did that too? HMM..
