Hatch wont open... Little help?
I wasnt sure why it was not opening. the lock was disconnected because the guy lost the key for it. and i have a different lock and key now to put in, but i had to get the latch mechanism because one side is broken i think. if looking at th elatches from inside the cargo area... its the right one. i disconnected the lever arm, and took off the 10 mm nuts that hold the coversand latch on. one side comes off, because that side works, but the latch that doesnt work, i cant get the ball of the pin that goes from the hatch into the latch out. i pull and i pull and i cant get it off... anyone have any hints? oh, and yes, i am trying to open the lock as i push, but the latch is broken so it doesnt do anything.
thanks for the help.
Get someone to pull up on the hatch while you work the latches from the inside.
IIRC you should be able to release the latch and pull it off of the hatch pins from the inside when the retaining nuts are off.
I think I have a set of latches from the early 944's somewhere in the garage. I will have to check them to see what may break inside.
Yeah, what SoCal said. I went thru this same thing last year. You need a helper to pull/wiggle on the hatch while you are inside trying to move the latch mechanism around.
If that fails:
J/K. Good Luck!
If that fails:
J/K. Good Luck!
In the early latches there is only one catch/blade the comes in from the side. The later latches have two blades/catches. So inside the unit there had to be a lever or gear or what ever to make both blades work.
Me thinks that this cross over has broken and you can only get one of the two catches/blades to disengage. You might possibly be able to drill a hole in the bottom of the non functioning side and use an ice pick or sharp awl to pry the catch off of the hatch pin.
If that fails:
(Picture of hammer)
J/K. Good Luck!
If that fails:
(Picture of hammer)
J/K. Good Luck!
...i disconnected the lever arm, and took off the 10 mm nuts that hold the coversand latch on. one side comes off, because that side works, but the latch that doesnt work, i cant get the ball of the pin that goes from the hatch into the latch out. i pull and i pull and i cant get it off... anyone have any hints? oh, and yes, i am trying to open the lock as i push, but the latch is broken so it doesnt do anything.
If you take off the other latch assembly, that is not stuck, you can see how it's supposed to work.
You might try using a small flat head screwdriver and slide it up the drain hole and try and push the clamps apart. I think they are hinged at the front of the latch assembly.
If that doesn't work, I'm not sure how you're going to get it off...
Good Luck,
If you have to use vice grips to break the assembly apart. Don't use a pry bar on any of it as you just may break the glass or bend the frame beyond repair.
I would look hard at the other assembly when you get it off as per jpapanas's suggestion.
