951 not starting
951 not starting
Hi, trying to get a 951 started. Disabled the aftermarket alarm, and bypassed the dme relay for trouble shooting purposes. We also replaced both crank position sensors. We get one strong spark on cranking and that’s it... ideas?
chrisxuereb12378 (06-24-2019)
Try un plugging the crank trigger sensors and plugging them right back in... That happened to me once.... must of been crud build up on the contacts.. They are VERY sensitive..
Thing is that there is continuity between the ecu plug, sensors, coil etc. Plugged a spark plug directly to the coil and we get one spark and that’s it. Thinking it could be frail wiring :-/
