944 Fog Light Reflectors (not the housing)
Hello fellow drivers. I am looking at fog light reflectors for my 944 turbo. You know, the shiny, curved part that is right behind the light bulb. My housings are fine, but I want to replace one of the reflectors.
It has part number 1 307 022 044 and is made by Automotive Lighting. I can't find much info on it. People usually seem to buy/sell the whole housing altogether.
Do 944 NA and 944 turbo use the same reflector? Do other non-944 cars use the same reflector?
Some 944 turbos have a dummy reflector which is flat and has the part number 1 301 099 041042 (this has no hole for the light bulb). I am curious about both but much more interested in the curved one.
I found these, but I have no idea if the reflector is the same: https://www.harborfreight.com/clear-...hts-37349.html
Thanks in advance!
Thanks in advance!
Rainman
If you can wait a few days I can dig through my boxes, I should have at least 1 spare pair that I'd let go cheap.
NA uses a different part altogether, I compared once
Once upon a time I saw someone fit some kind of compact light by cutting a hole in one of the dummy reflectors too. I might have spare dummies if you wanted to try that.
bonus12 (06-23-2019)
Hey V2Rocket, good to see you on the boards. I'm definitely interested in what you have, so I'll wait a few days. Thank you for that, and the interchangeability info too. I should have guessed they're different!
When looking over my reflectors, the silvering of the reflector was peeling off the reflector body itself..Anyone out there have any experience with how to re-furb or re-chrome the reflector itself? Just wondering..
