Does Dansk pre silencer fits 88 Turbo S?
By mistake I bought two of these:
https://www.design911.co.uk/fu/prod5...-Dansk-92445S/
EXHAUST PRE-SILENCER. PORSCHE 944 / 924S
Code: 94422092445S
Intermediate exhaust. Polished stainless steel.
Fits:
Porsche 944 1982-89 (8V Engines) 2.5L / 2.7L
Porsche 924S 1986-88
I found a buyer but I'm not use it's going to fit his Turbo S? The description from the store says it does, but as far as I remember from the Turbo comercial, the Turbo has different exhaust from N/A. So will it fit?
Code: 94422092445S
Fits:
No do not use that on your Turbo S. It won't bolt on and even if it did, the pipe diameter is way too small. If you want to delete the cat on your Turbo S, just cut the cat off at either end and use a 2.5 inch straight exhaust pipe and you can clamp it in. You can sell those DANSK pipes on eBay.
