View Poll Results: Has your 944 ever left you stranded?
Yes: It was MY fault (Left lights on, etc.)
![](https://rennlist.com/forums/images/polls/bar2-l.gif)
![](https://rennlist.com/forums/images/polls/bar2.gif)
![](https://rennlist.com/forums/images/polls/bar2-r.gif)
![](https://rennlist.com/forums/clear.gif)
16
8.74%
Yes: It was THE CAR's fault (something broke)
![](https://rennlist.com/forums/images/polls/bar3-l.gif)
![](https://rennlist.com/forums/images/polls/bar3.gif)
![](https://rennlist.com/forums/images/polls/bar3-r.gif)
73
39.89%
Yes: It was something uncontrollable (flat tire)
![](https://rennlist.com/forums/images/polls/bar4-l.gif)
![](https://rennlist.com/forums/images/polls/bar4.gif)
![](https://rennlist.com/forums/images/polls/bar4-r.gif)
9
4.92%
Nope
![](https://rennlist.com/forums/images/polls/bar5-l.gif)
![](https://rennlist.com/forums/images/polls/bar5.gif)
![](https://rennlist.com/forums/images/polls/bar5-r.gif)
85
46.45%
Voters: 183. You may not vote on this poll
EVER broken down?
#77
The Hoffinator
bpp.. youve seen my record, and im obsessed with preventitive maintenence. sometimes when a car wants to break down nothing is going to stop it.
#78
Originally Posted by bpp944
Pearldrum944,
I've had plenty of problems w/my cars, but preventive maintenance has always kept me from being stranded.
#79
I've owned my '89 Turbo since new and have NEVER been stranded. That's 15 years! I came close on one occasion, though, when the clutch developed problems (the infamous broken springs) but I was still able to limp home.
#81
Haha, great stories. Sounds like none of these things are very bad for cars as old as this. I dont have a 944 yet but I'm searching for a Turbo right now, I have a good $9,000 able to spend on it right now.
#83
Originally Posted by pearldrum944
Hod does the clutch act when springs break?
#84
Originally Posted by Jake951
It feels as though the shifter is jammed and you can't shift into gear. In my case it was intermittent when it first appeared, so I was eventually able to get the car moving.
#85
Got stranded for the first time last saturday...
I was coming home from Castro Valley in the wee hours of saturday morning when I heard a very (very) slight pop and then no more going. Thought it slipped out of gear (which worried me enough) but it wouldn't drive in any gear. Moderately long story short, I got towed home and the clutch was the culprit. Hooray for not needing to replace my transmission (sorry tifo :-P). Ironically, I was planning on putting the car up in the air on the very same saturday to fix said clutch. I had the new kit in the car with me, and my spare flywheel was in the process of getting machined. Ahhhh irony.
So, funny experience, except that was I was 9 miles outside my free tow radius, but the driver wrote it up as 8 and popped the lock on my friend's vette for free. (OT, but those cars are _not_ designed to be easy to get into.)
--Chris
--Chris
#86
Registered User
My 83na broke down 500miles after changing the belts at a porsche garage and 600miles from home.
The spline holding the cam shaft was missing.?? Result ? crushed some of the valves and rods ..etc etc.
Actual the engine didn`t die, And I drove it up on the rescue truck myself!! but I gotta say, it sounded like a old Merscedes diesel praying its last prayers...
Anyway I pretty much ended up changing most of the engine spending 1200$ , And the guys at the garage even put on a ported head from a racing 944 at no extra charge...
#90
Well, since this forum includes 968's, I'll mention that the PLASTIC(!!) impeller on the water pump decided not to turn anymore. This, after I thought the overheating was due to the thermostat. After spending time and effort to change the thermostat, the impeller eventually gave way! My mechanic replaced with a pump that uses a metal impeller.
Bill...
'92 968 cab.
Bill...
'92 968 cab.
