Fiberwerks bumper photos?
TRB0 GUY
I have a beef with the side vent... what is it's purpose. It seems that if there aren't NACA ducts behind it, or other form of ducting to the brakes... it's only there to create more drag.
Can you order it from Fiberwerks w/o the side markers? Or, how would one go about filling in that space, and is it something an amateur could pull off? I think it would look much better w/o the side markers, but your pics would probably help me make up my mind... *wink *wink...
i got mine from Ian over there at 944online.com....those guys are great...see what they don't tell you about ordering from fiberwerks is that it takes like 2 weeks for them to get it to you....i had mine from 944online within the same week that i ordered it....not even on rush delivery....i def. recomend calling them up to see if they have one on the shelf.....
i did the side markers, and what i did was grind out the "braket" for the sidemarkers, and make a rough cardboard template of what i wanted the corner to look like. Then i used fiberglass mat and resin to make a corner for each side of the bumper where the marker light was....after that dryed i used alittle fibreglass filler to make up for the wavey texture,and sanded smooth, then some blocking and polyester filler, primer and drilled the new mounting hole to bolt it to the fender. TADA!!!
