Early 944 dash lights don't work
I just replaced the clutch on my 84' 944 and it was fine for a few days but now the dash lights dont work and the headlights wI'll pop up and turn on but won't go down for a while after I turn them off. Any help?
Dan M is correct..when things start to go wonky with electrical circuits, the first place to go to is grounds..There are ground sites on the frame rails (both sides) up front that run the headlight circuits and several others as well. Take all the brown wires off the posts, clean up all the brass ends and the posts and re-connect..should be better..There's also a major grounding site in the rear of the car, driver's side..probably needs cleaning too. just sayin.. Hope this helps some..
