Pics of my failed Cam Tensioner
Scary to look at. Glad I changed mine without going through what could have happend...but you never know. The chain rides on a small piece of plastic, with doom waiting beneath it!
Great job Porsche!?
Great job Porsche!?
exact same pics as posted on my website of MY head eight months ago. i can't believe how many 16-valve owners on this website have had this same problem.
good luck!!!
see my website below for further pics and so on regarding my head damage
good luck!!!
What do these chain tensioner assemblies go for at the dealer?
Also is the process of replacing it something that is not overly difficult to complete?
Originally posted by mpw
Have any aftermarket suppliers attempted to reengineer the tensioner? Like say, machine the pad and tensioner as one piece?
Good you are seing this mpw. Still going to buy that S2? I hope you do, just change the tensioner when you get it.
If they just put a chamfer or radius on the metal plate so the chain would still slide over the top instead of catching on that right angle and pulling it out of the head....
The mean failure mileage is 100k miles. Replace it before then and then every 80-100k after, and you're good to go.
Dal.
Originally posted by AndyK
So what didn't you like about the '91?? Condition, or drive quality, etc?? Was it the first S2 you drove? Details, man, details!?
It drove very well for a 104k mile car. The body and paint are in excellent condition, except for a bit of damage to the right rear quarter panel behind the rear wheel. The rear diffuser (not sure if that's what you guys call that thing) is a bit gouged. This damage was disclosed in the add, so it was not a surprise. There are little electrical gremlins, the airbag and seatbelt lights will not shut off and the interior bulbs are burnt out. The interior itself is in excellent condition and there are no cracks or blemishes as far as I could tell. The car is VERY clean inside.
I guess my reservation is that I think the asking price is a little high after finding out that it did not have the LSD or the M030 package; both were big selling points for me. My only other concern is that the car has been the owners extra/weekend car for the past few years and hasn't been driven that much. Since it will be my daily driver, I'm worried what might pop up when it starts getting used again. Overall, it's a really nice car. It idles smoothly, the transmission feels good, and it looks great for a 13 year old car. I'm going to talk to the owner about the lack of an LSD and the M030 package and see what he has to say. He seems like a very nice and honest guy, so I really think he didn't know the car didn't have those options or it's my mistake and they aren't listed on the sticker.
Finally, I'm wondering if I should just bite the bullet and get a 951. I didn't push the S2 when I was driving it since it wasn't my car and the owner was nice enough to let me take it out on my own. I'm just not used to an engine that you need to wind up to get power out of it (although that's not a bad thing and something I'd really like to have).
Good luck in your search,
Administrator - "Tyson"
What still puzzles me is the 928 S4 is the same design. You do not hear about these breaking on 928's.
I was semi-lucky when my chain broke. All 16 valves were ok, the head was ok, but both cams were shot.
When I was shopping for a short block after my bearing spun, many places had lower ends, but no heads for the 16V.
Good luck.
Good luck.
My theory is heat. The 32v 928's get 300-350HP from two heads, so 150-175 each side. The tensioners turn orange-brown but they never seem to crack, at least not in the usual couple hundred thousand miles.
The heads are also not on top of the motor pressed close to the hood, they might run a bit cooler if more air circulates around them.
The cam specs and valve springs might also be an issue, if the 928 cams are easier to turn there would be correspondingly less force on the chain.
I suppose the S makes close to 1/2 a 928GTS's HP, but not a lot of GTS's have been run up to really high mileage. It will be interesting to see how the GTS's fare in the over 100K mile timeframe.
-Joel.
-Joel.
