Ignition coil
Old 12-05-2018, 04:26 PM
Swenny
Swenny's Avatar
Default Ignition coil
Anyone use a "Flamethrower" ignition coil? I used one on another 924S 15+ years ago but I don't remember which one I had used.
Old 12-05-2018, 07:05 PM
Jfrahm
Jfrahm's Avatar
Why? Did you also increase spark plug gap? Stock coils are robust and make a fine spark.
Old 12-05-2018, 07:27 PM
V2Rocket
Rainman
V2Rocket's Avatar
yeah, "upgraded ignition systems" are high-grade snake oil that don't do anything but lighten your wallet, if you're going to keep the same plug gap.
Old 12-05-2018, 07:34 PM
Swenny
Swenny's Avatar
They're cheaper to purshase.
Old 12-05-2018, 07:57 PM
T&T Racing
T&T Racing's Avatar
But can negatively affect the DME
Old 12-05-2018, 09:46 PM
Jfrahm
Jfrahm's Avatar
Not cheaper than a used stocker or rando coil from a Jetta. Assuming your stock coil is bad (this is unlikely).
(edit, or used off Volvo, Saab, BMW, etc.)
Old 12-06-2018, 08:58 AM
Tiger03447
Tiger03447's Avatar
Is your coil hot to the touch while the engine is recently shut off? A bad one will be so hot that you can't touch it..
Old 12-06-2018, 09:16 AM
Swenny
Swenny's Avatar
It works just fine,tests within specs and is not hot (warm) unless it's 110° outside. I'm going through every system and updating with 21st century made parts when possible. I plan on doing a road trip. Thanks to everyone for the insight into coils.
Old 12-06-2018, 03:26 PM
divil
divil's Avatar
It's well worth reading this before making any changes from the factory coil:
944/951 Ignition System Testing
That explains the issues with using different coils without an appropriate DME software update to account for the different charging time.
Old 12-06-2018, 07:47 PM
tempest411
tempest411's Avatar
I'd add my own. 02 in telling you OEM electronic stuff is most always more reliable than the aftermarket, no matter how fancy it may look, or the bold claims the manufacturers make. A rep from Wells-Ampco once told us that the vast majority of aftermarket ignition coils sold were to customers replacing perfectly good OE coils, which were improperly diagnosed.
Quick Reply: Ignition coil
