Valuing a '91 944S2
#46
Originally posted by Riff
Based on the modifications you are planning to do to the suspension, the premium you are really paying for for MO30 on the S2 are the larger front brakes and the LSD.
- Matt
#47
Originally posted by Tom R.
Now back to the LSD issue. If there were two used S2s next to each other with identical miles, in identical condition, etc. How much more would you pay for the car with LSD/M030? Probably not more than around $300. That's why it isn't really a factor in price. Would you pay much more than $300?
#48
Originally posted by jonnybgood
I still have many miles of learning ahead of me in my 944S before I will need to consider upgrading the differential and sway bars. Looking at ads though the rear M030 roll bar is at least $300 new (Weltmeister aftermarket). An LSD used is usually $800 to $1k, new racer LSD is $1k before installing into the case. To have all that on the car without having to spend a few weekends away from my girlfriend to install is worth at least $1,500 to me!
That S2 is starting to look like a bargain, isn't it?
#49
I dont think (but am not sure) the M030 has the 928 brembos the 951S had. I think the brakes are the same 951 brakes.
I dont think the lsd/M030 adds that much to the value, but maybe it does.
Pete,
Im looking at SCs, and the low mileage 944 by me keeps popping up in my mind as an alternative. Just wanted the opinion of someone who lived with both. I drove my brothers NA last week, and thought i was starting out in third even though i was in first, but that was coming right out of the camaro, and it took a while to get used to keeping the revs up again.
Pete,
My NA never had great torque but if you kept the revs between 5 and 6K it was a lot of fun. I would miss the torque but I never owned a car that 'fit' me like a 944 does.
#50
I dont think (but am not sure) the M030 has the 928 brembos the 951S had. I think the brakes are the regular brembos from the non S 951.
"A 944 S2 equipped with the very rare M030 Sports Suspension option uses the same size front brakes as those used on the 1988 944 Turbo S or 1989 944 Turbo. These larger Brembo calipers first appeared on the 928 S4 so are routinely referred to as the "S4 brakes." The piston sizes are 36 and 44 mm and the corresponding brake pad width is a very substantial 132 mm. The front rotors used with these "S4" calipers have a diameter of 304 mm (11.97 in) and a thickness of 32 mm (1.26 in).
M030 cars use different steering knuckles and hubs. Different knuckles are required because the S4 caliper attaches using a radial mount as opposed to the axial mount for the standard caliper. Different hubs are used to accommodate the 4 mm increased thickness of the M030 rotor."
#51
Originally posted by 944pete
I'm not 100% positive about the brakes either but I know the M030 package was more of a complete suspension package.
Now the other thing is the condition of the suspension components. Even though they are MO30, they are still 12 yrs old!
Originally posted by mpw
The brakes alone are worth the premium
I am not tryin to sway you from the purchase of this car, but the MO30 suspension was not "that" great of an upgrade. On my S2, I installed some M474 Koni's (precursor to MO30, not externally adj.) with the stock springs, but by far the better upgrade was the front and rear sway bars from the 968 MO30.
The larger front brakes would be nice, but since I mostly AX, I do not come close to maxing out the braking system. I will be trying to attend DE's again this year in the NE after a few year hiatus, but at previous events (Mid-Ohio, Putnam Park) I always had plenty of brakes.
Good luck with the PPI,
#52
BTW MPW in case you have not found it, check out this site for some very useful info on the S2 Tom's S2 site
- Matt
#53
This is an interesting post for many reasons.
First, I'm not sure what the printed valuations matter; i.e. Excellence, NADA, KBB; since you need to decide what the car is worth to you. I know that the ACV on my 1990 cab is $15k. This is from Leland-West. The PCA valuation on the car is $18k. I paid $13900. These quotes are around two years old. When I was looking I think Luis's Champagne and Black cab was for sale in the neighborhood of $14k with 125k on the clock.
My car is your basic 944S2 Cab Rad/Black/Black and now has 101500 miles on the clock. Actual miles are around 91k because my speedometer/ odometer is about 10% on the happy side. I do TSD Road Rallies and this difference seems to be fairly consistent.
In the course of three years of ownership I've probably dropped $4k in service and pieces parts, some of which are still sitting in boxes. What you want to do is irrelevant to the seller. As long as the car is solid and gets a good PPI and how bad do you want it, that is what the price will hinge on.
Anyway, Koni will rebuild the shocks for $100 each and the struts for $140 each and you cover shipping. It should take about four weeks. Here's a contact, Paul Mclaughlin <PMclaugh@fluids.ittind.com>.
Sorry about the ramble, but everyone has an opinion on price points, but the only person that really matters is you.
#54
Originally posted by craig001
Anyway, Koni will rebuild the shocks and struts for $140 each and you you cover shipping.
- Matt
