Draining Coolant
Draining Coolant
Does the water jacket empty completely (or adequately) thru the water pump? i.e. pulling the lower hose and thermostat empties the block?
Had to replace coolant at a track event this fall with water and want to make sure I don't have a freeze problem now that the cold weather is here.
Rainman
my experience, no it doesn't completely empty the block but gets most of the way there.
you'd probably have to have the back of the car lifted higher so the coolant flows downhill towards the WP.
When I prepare my race car (BMW E30) for the winter, I just empty the radiator, then fill it up with 100% antifreeze. Then run it up to temperature. It ends up being about 40% antifreeze mixture which gets me through the winter.
Then when it's time to hit the track, I completely drain everything and fill with water and wetter.
Oddjob
I drain the radiator and then remove the lower hose where it attaches to the radiator. Then, after insuring that the lower hose is clear of the power steering pulley, I start the engine and wait for the thermostat to start opening. As it opens, it allows the coolant to drain out of the block. As the flow starts to diminish, I shut the engine off so as to not allow the water pump to run dry and I then reinstall the lower hose once the flow becomes a dribble. Have done this countless times over the years both on my cars and all the similar designed cars that we service. Some may be uncomfortable with this method and if you are don't do it, but it works.
Cliff
Cliff
That drain plug is on my '88 951 (I think it's an August '87 build).
FYI when I removed my head, I drained via front hoses etc. and there was plenty of water in the rear cylinder area and some in the bottom of the other three
