help!!! 1984 944 transaxle problem
It's hard to tell from the video, but it looks like the axle is spinning and not the wheel?
It's one of two thing:
-Most likely - the axle bolts on the outboard side have backed out
-Less likely - the outboard CV joint has failed
Yes it spins but the car won't move. And isn't the diff supposed to transfer movement to the other wheel?
Not with an open diff. The power takes the path of least resistance. If one side can turn with no resistance, then the other side gets no power. Look up an animation of how an open diff works and you'll see why.
944s aren't really the kind of car to drive that way. They'll break pretty easily if you do. An old Camaro would be a far more practical candidate for that sort of abuse. V8, solid rear axle, super-cheap and easy to fix, can't beat it!
