What oil?
What kind of oil would u guys reccomend putting in the 951? I am going to put in mobil 1 full synthetic but i dont know what grade(i guess thats the word) to put in it
I've used the mobil 1 15 50 (red cap) in my car for years now. After 90K and 1000 track minutes, my bearings and cylinder walls were perfect. Be prepared that when you switch to synthetic if you have any weak seals or gaskets it will leak. My car was like a strainer for the first six months.
it is expensive, but worth it.
i run castrol 20w50 in my car, she runs well, and no leaks, i don't think i'm going to change it to synthetic though. its a good idea to check everything out under there every 3k miles anyhow
you never know what could be happening!
-Michael-
-Michael-
Another benefit I've heard is that you don't have to change the oil as often, is that true?
Heh, that statement confused me as well.
If you live in a colder climate, use 10W30 in the summer, 5w30 in the winter. In warmer areas, I would use 10W30 winter, 15W50 summer, and if you are lucky enough to live in CA or FL, 15W50 year round.
iloveporsches, Not all brands are the same, especially with synthetic, sounds like your friend was generalizing about something he is not familliar with. Check out the wear tests.
Yes, all oils are roughly the same initially, they come from the same group #, then they have the same stock, that part is the same, but the additives are what makes the difference. Look at the wear difference between Amsoil and Quaker state (both synthetic), that's a good indication of how different they can be.
Maybe certain brands, like Amsoil, are a cut above, but this company bottles lots of different brands, and guess what...the same stuff goes in the bottles with different labels. So *many* brands are the same, not all.
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
I use 15W50 in my car. It runs great on the track and at autoX, but it does go through a quart every two or three months, which represents about 200miles of driving to, from, and at events.
Originally posted by Friendan
Hey Jeremy, after those 6 months did you replace the leaking seals or did the problem just correct itself? I have been thinking of switching to synthetic but I have been concerned about that problem.
iloveporsches, I was sitting down thinking about it the last night, and I think I figuired out what your friend meant.
Brands like Quaker state, Pennzoil, Mobil 1, Amsoil, etc... are different oils, but ones like Motomaster Synthetic, and other house brands of synthetic oil probably are the same oil as another (probably low quality) brand.
When I read your post I presumed you meant ones like Amsoil, Mobil 1, or others. And that just wouldn't make sense to me.
Although it is possible they are all bottled at the same plant?
ag951, don't make me more mad than I already am over the weather!
lol.
I just saw the forecast, and next week, we are hitting -40 for 2 or 3 nights (EEEK!!), with highs of only -30 (celcius) for those days as well. And here I am, with only an oil pan heater, no block heater (yet, I am going to look for one today!!!)
Up until now, the coldest we hit was -25, and recently, we have had overnight lows above the freezing point, with highs of 5 or 10 degrees for the last 2 weeks, this will be a big change!
lol.
