RHD & the Battery
RHD & the Battery
I was under the impression that the battery was in the trunk of all RHD cars, to make room for the brake/clutch assemblies. Someone then posted that the battery of some was actually in the engine bay.
The reason for asking is if with LT-1 conversions if it would be possible to move the battery to the trunk to move some weight to the rear, and maybe even use some of the ideas to keep power brakes?
Anyways can someone post some pics/information on the RHD battery location & power brake assemblies?
Originally posted by ilikemy944
If the car were RHD then that brake booster would be right where your battery is.
Originally posted by Manning
Well, not exactly. The brake booster on a 944 is in the engine compartment, not the well right in front of the windshield where the battery normally goes. Also, in all the pictures I have of RHD 944s the booster is in the same location as that for a LHD and complicated linkage is used to make everything work. I just don't get why the battery gets moved to the back.
Anyone have any pics?
Yeah, I'll scan some later. I can't really see much in that area in the pics I have though. May be linkage. I do see that vacuum accumulator thingy, but that's next to the battery on my car too.
Maybe a UK lister could jump in here huh?
Late models had the battery in the rear, early in the front, I moved mine to the rear in a marine box. The brake pedal is done via linkage.
Late models also had the wipers going the other way, I reversed mine.
I have a couple questions since the pics are up.
What is that brown canister, above the headlight motor, next to the distributor and winshield washer fluid in the white car.
And in the red car what is the little dirty white canister way up in front of where the battery is supposed to be. I'm just asking because i don't have these things in my car.
