Remove speed impulse sender from gearbox
Hi I have an 86 944 and the speedo is acting up. I want to take the impulse sender out of the gearbox and clean it. Can someone tell me how it can be removed from the gearbox. Does it screw in? Also I dont have a ramp so I will be layig under the car. Any advice appreciated
So I went out and tried to pull it off. Basically part of it came off and it was a cylinder shape at the bottom and it was a circuit. I feel like I may have broke it. Il get a photo in the morning and maybe you guys can advise me better
Oh man! I actually knocked my original off like that by accident (working on something nearby). I never could get the two halves back together and working; i tried cleaning the contacts on that circuit board and lining it up, but nothing.
You'll probably have to buy another. I guess you didn't unscrew it fully?
I have a new one ordered because my speedo is playing up. I was just trying to work out how easy it would be to fit the new one. I have these photos i screenshotted from a video. Hopefully you can interprit them. Also how can I get the lower bit out? It seems like its almost part of the box.
Unless yours is somehow a different type than mine, that bottom part comes out; you'll have to snap the top part back on and work on unscrewing it.
You broke it, I don't believe it can be easily repaired but perhaps worth a try. I have a few on the shelf and can sell you a good used one. Or it can also be sourced from recyclers such as 944 Ecology, dcAutomotive, etc.
Obviously, the replacement doesn't get torqued too tight; it's plastic
Thank you very much you have been very helpful. Its much appriciated
To the other guy that responded about having some- Ive actually already ordered one directly from porsche. They are only charging £45 which isnt too bad
