Brake pad wear dummy light off! Problem solved!
Finally fiquired out why my dummy light wouldn’t turn off. After replacement of the sensors on all four conrners, I found the light won’t go off. Turned out to be a ground that needed cleaning. Feeling happy!
Funny.. I got the exact same issue right now. Gonna check those grounds.
PS I like your jack stands: the appear to have flat tops, correct? All I seem to find up here are the silly "wide U" shaped topped ones. Where did you get those?
Yes those darn grounds! Really is worth going over all of them!
Got the stands from amazon. Esco brand. Work very nicely.
