Strange Hood fitting issue
As I continue always looking for things wrong lol..............
Anyone experience an odd hood issue where it has clearly begun rubbing on parts yet still fits fine according to fenders on outside?
It likely not going to be engine mounts because one of the points you isolated is the expansion tank. Since that point is bolted to the fender wall and inside wheel well the engine mount is not going to play a roll there. The hood mounting arms allow a lot of play since you can make a lot of adjustment (both vertically and horizontally) with the 2 oval holes. When I was reinstalling my hood just recently I placed 3 or 4 tape markers on the fender for locations to measure the hood/fender panel gap with a caliper. After about 10 trails I eventually got some clarity as to what a minor adjustment was doing to the measurements. The job is pretty fiddly; and I couldn't find any particular procedure in the FSM for it other then trail and error.
Say, does the hood shape deform over time? I haven’t had the insulation and wondering if the heat has caused some changes. On the left, the hood appears not to follow the fender exactly anymore, rising slightly in the middle of the run.
The hood mounting arms allow a lot of play since you can make a lot of adjustment (both vertically and horizontally) with the 2 oval holes. When I was reinstalling my hood just recently I placed 3 or 4 tape markers on the fender for locations to measure the hood/fender panel gap with a caliper..
NelaK: might be a little wait
