924S elevated hub steering wheel?
hoping someone can identify whether this steering wheel has the standard hub attached, or is this the M018
option, elevated hub? extension is about 31/2" to 3 3/4" in length. thanks!!
M018 - SPORTS STEERING WHEEL WITH ELIVATED 30 MM HUB
So If the stock hub is 4in (100mm) and the M018 is 30mm longer, then the hub length would be 130mm by my math
M018 left, stock height right, source: https://pin.it/jbqdsyshqchdry
Look what I picked up today... an original "sport option M018" steering wheel with the 30mm extension on the back!
I'm going to try and retrofit the extension on my airbag wheel. I don't care if I lose the AB function.
The SW is in terrible condition (as described: needs the leather recovered). Standard non-sport diameter is 380mm and sport is 360mm (this one is 360mm & my airbag wheel is 380mm). Sport SWs came without extension and with. Howover, the extension isn't an add on per se: you can't use an M018 SW complete without the extension as the cage doesn't have the splines. Cages seem interchangeable though.
Very easy to remove the extension: three allen bolts. All looks original.
Aparently, Porsche recommended this extension for anyone 5'10" or taller. My seat is two clicks up from the rear and my arms have always felt a bit too extended.
If I can't use the extension on my AB wheel--even with small modification, maybe I'll re-leather this one. Yes, I like the stock wheels
FYI stock Porsche wheels are offset slightly: the centre of the rim is 12mm higher than the mount point. Aftermarket SWs usually aren't, so far as I can tell. Pelican does sell an adapter to compensate an aftermarket SW for this.
Just adding more info that I couldn't easily find on this topic
Last edited by Dan Martinic; 11-02-2018 at 03:36 PM. Reason: Revised stock SW offset to 12mm
