corroded fan resistor wires
Is there a fix for properly removing green corrosion from the four fan resistor wires that are located under the plastic cowl protector? I removed the remaining wire insulation that was rotted and wiped off the bare wires, then I wrapped them seperately in electrical tape. The fans still work without issue. Is this enough or should I try something else? TIA
