Cracked the batwing - best adhesive to make the repair?
You’ll want to use a plastic stapler to give it some rigidity, and then fill it however you like. Something like this - https://amzn.to/3ybHLOn - I bet Harbor Freight has something similar.
944Fest (aka Dan P) (07-02-2022)
I can attest to having tried everything listed above except for the stapler. All eventually fail, and in the end zip-tie stitching is really the only thing that lasts. My best guess is that the batwing vibrates and flexes a lot at speed.
If the batwing is manufactured from ABS, which I think would be the case, you can repair by "welding" it together using a large soldering iron and a further scap peice of ABS as the "welding stick".
Make sure that the edges are clean, the area to be repaired is firmly held together to stop it from moving as you heat it and it gets soft and that the soldering iron is large enough to maintain temp at the close to melting point of the ABS. It is a bit of a cross between welding and soldering and not that difficult. Work from the inside and have the outside on a clean surface so it does not pick up dirt while soft. For extra strength you can weld a strip of ABS behind the crack on the inside of the piece.
Experiment with scaps until you get the technique down pat and have fun. I have done this on quite a few ABS repairs and construction projects.
