Oil in Coolant after water pump replacement
1984 944 2.5 NA. So on Sunday I finished up the timing belt/water pump replacement project and everything went smooth, car ran great sitting in the garage. Monday evening when bleeding the cooling system I noticed the "milkshake" in the coolant reservoir. I pulled the lower radiator hose and the brown sludge came out. I then removed the block plug to drain the coolant out of there an it came out without any contamination. I also drained a bit of oil to check it and the oil was fine, no coolant in it. What's troubling me is when I first began the timing belt/water pump installation and drained the coolant there was no contamination. I did pressure test the cooling system at 13-14 psi and left it pressurized for about an hour before installing the belts. Is it possible to have blown an oil cooler seal pressure testing the system? Should I just plan on pulling the oil cooler and replacing the seals?
Sounds good. Guess I'm doing the seals. Was looking at the alignment tool on pelicanparts just now. Not too expensive (around $32 with shipping) but there is also one on ebay for $20 but its made out of a hard plastic. Cant decide which to go with.
I've got the opposite problem.
Coolant tank was empty, drained oil, it was a milkshake and 3 quarts over filled.
Drained cooling system, coolant looked new but most of it was missing.
Time to pull the head....
Ouch, I was happy when the oil I drained came out clean, well dirty but not coolant contaminated.
The more I think about this the more confused I get. When I pressure tested the cooling system at 13-14psi it did not drop for the hour it was pressurized. Wouldn't it have dropped if it blew an oil cooler seal?
Finally got around to installing the kit, seems to have corrected the problem but time will tell. Still cannot figure out how the seals could cause coolant to get into the oil, but not also oil in the coolant.
The oil pressure relief valve was closed and sealed the oil system, therefore no coolant in oil and the test showed no leakage, no pressure drop.
I would suggest pressure testing the oil cooler after removal.
